Thomas,
its the same node combinaison except it is in 1.5.
Sorry I cannot send the file, is too huge.
I’ll try later your recommendations on latest version and let you know
Best
Thomas,
Best
Which view type is on your sheet? I’ve mocked up your graph and it works for me without issue.
If you can send a file with just that sheet and view and delete everything out of your model appart from some information to show in the views, that will be enough for me to investigate the cause. I would recommend you use DuplicateSheets v2.0 over v1.5.1 as it has some major improvements, and if there are any bugs, naturally I want to eradicate them!
@yien check this out: it might be a simple case of upgrading to bimorphNodes v2.0.3:
