Duct and linked Wall intersection
I have followed a youtube from Bimorph Here to create a graph the report the point the ducts clashing with walls.
I have used “Arch Link Model” from “C:\Program Files\Autodesk\Revit 2021\Samples” and placed all the ducts at 1500mm elevation.
It seems to work in some of the areas, but not everywhere. I have highlighted the area that it has worked in yellow and put red circles where it has not worked.
Not sure where I have gone wrong, any help will be appreciated. Thanks
Wall Duct Intersection.dyn (33.0 KB)
Hi @Hoss not sure but could these walls be curtain/ stacked walls ?
Wall are from a same type.
I have changed my graph like this and it is working fine now. Thanks
I was wondering if there is a way to achive this using python script
tried to use this Finding intersections points between pipes and walls - #12 by c.poupin, but its not working
is there an error or the result is wrong?
I have changed the code as follow, since I have the wall in the linked model and ducts in my current model and testing it in RevitPythonShell . I have only one linked model, so didn’t need to filter etc
from Autodesk.Revit.DB.Mechanical import *
l_doc = ""
linked_docs = FilteredElementCollector(doc).OfClass(RevitLinkInstance)
for link in linked_docs:
	l_doc = link.GetLinkDocument()
linked_walls = FilteredElementCollector(l_doc).OfClass(Wall)
ducts = FilteredElementCollector(doc).OfClass(Duct)
lstIntersect = []
for duct in ducts:
    curvduct = duct.Location.Curve
    for wall in linked_walls:
        linkrefface = HostObjectUtils.GetSideFaces(wall, ShellLayerType.Interior)
        intFace = wall.GetGeometryObjectFromReference(linkrefface[0])
        interArRef = clr.Reference[IntersectionResultArray]()
        if intFace.Intersect(curvduct, interArRef) == SetComparisonResult.Overlap:
        	pointIntersect = interArRef.Value[0].XYZPoint
        	lstIntersect.append([duct, pointIntersect.ToPoint() ])
OUT = lstIntersect
running it like this will give the error “‘NoneType’ object has no attribute ‘Intersect’”
so I change the line where I am collecting walls to
linked_walls = FilteredElementCollector(l_doc).OfClass(Wall).WhereElementIsElementType()
now, I don’t have any errors, but the output list is blank !
I have done some more testing and if I have all the walls and ducts in the same file, ie no linked model, then the script works and report the coordinated of all the intersection points.
So I guess I need to figure out how to transform the linked model so they are in the correct place
wish me luck :smiley:
Hi @Hoss ,
you need to apply 2 transformations,
here is an example with link models with transformation
import sys
pyEngineName = sys.implementation.name
#import Revit API
clr.AddReference('RevitAPI')
linked_instances = FilteredElementCollector(doc).OfClass(RevitLinkInstance)
pipes = FilteredElementCollector(doc).OfCategory(BuiltInCategory.OST_PipeCurves).WhereElementIsNotElementType()
lstIntersect = []
for pipe in pipes:
    curvpipe = pipe.Location.Curve
    for link_inst in linked_instances:
        l_doc = link_inst.GetLinkDocument()
        l_tf = link_inst.GetTotalTransform()
        linked_walls = FilteredElementCollector(l_doc).OfClass(Wall).WhereElementIsNotElementType()
            # apply the inversion of transformation on curve
            curvetf = curvpipe.CreateTransformed(l_tf.Inverse)
            if pyEngineName == "ironpython":
                clash = intFace.Intersect(curvetf, interArRef) == SetComparisonResult.Overlap
                clashPoint = interArRef.Value[0].XYZPoint if clash else None
                dummy_out = IntersectionResultArray()
                result, interResultArr = intFace.Intersect(curvetf, dummy_out)
                clash = result == SetComparisonResult.Overlap
                clashPoint = interResultArr[0].XYZPoint if clash else None
            if clash:
                # revserse the transformation
                clashPoint = l_tf.OfPoint(clashPoint)
                lstIntersect.append([pipe, wall, clashPoint.ToPoint() ])
OUT = lstIntersect
Hello @c.poupin
Firstly I would like to thank you for your help
For your information, I have the architect model linked to my MEP model. So walls are from linked model and ducts, pipes etc are in the current document.
When I try your script, I get this error
  File "<string>", line 45, in <module>
AttributeError: 'NoneType' object has no attribute 'Intersect'
this is the line
Thanks again for your time
the error indicates the variable “intFace” is null, try to debug filtering the culprit walls (curtain walls?)
Thank you very much for your help
I should have noticed that as I did print out the results from that line and I could see some null values :crazy_face:
Thanks again
