Finding intersections points between pipes and walls
Hello
another way to find intersection on a Wall Face with Intersect Method (Curve, IntersectionResultArray)
clr.AddReference("RevitAPI")
from Autodesk.Revit.DB.Plumbing import *
lnkInstWall = UnwrapElement(IN[0])
lnkInstPipe = UnwrapElement(IN[1])
docWall = lnkInstWall.GetLinkDocument()
docPipe = lnkInstPipe.GetLinkDocument()
lstWall = FilteredElementCollector(docWall).OfClass(Wall)
lstPipe = FilteredElementCollector(docPipe).OfClass(Pipe)
lstIntersect = []
for pipe in lstPipe:
    curvPip = pipe.Location.Curve
    for wall in lstWall:
        linkrefface = HostObjectUtils.GetSideFaces(wall, ShellLayerType.Interior)
        intFace = wall.GetGeometryObjectFromReference(linkrefface[0])
        interArRef = clr.Reference[IntersectionResultArray]()
        if intFace.Intersect(curvPip, interArRef) == SetComparisonResult.Overlap:
            pointIntersect = interArRef.Value[0].XYZPoint
            lstIntersect.append([pipe, pointIntersect.ToPoint() ])
OUT = lstIntersect
Note: if you want the middle Point Intersection get the second face with HostObjectUtils.GetSideFaces(wall, ShellLayerType.Exterior) then calculate the middle Point with the 2 IntersectionResult
