Hi there,
I am currently working on a dynamo script to create simple tapered elements.
I ran into a problem where revit started to give me constraints. This might be a revit related issue.
This is the script I am currently running:
It works fine for rectangular elements, but when i use an element like below it starts giving constraints when it fills in the parameter values
I think this happens when both the LB and LO parameter are the same value. After that happens it won’t be able to turn into a tapered element anymore.
Any ideas on how to fix this / or work around it?
Thanks in advance!
