Detail Line Not Drawing Correctly
I am attempting to draw a simple detail line on a section view in Revit, and the curve shows up drawn correctly in the dynamo display area. But when viewed in the section in Revit, it shows up wrong. Any thoughts on how to fix this?
Script:
Output:
Is that view a proper elevation ? or a drafting view ?
If it is a drafting view- then there is no z dimension (vertical is y)
Andrew
It is a section view. However, for some reason the out of the box node “DesignCurve.ByCurve” doesn’t work but the “DesignCurve.ByCurve+” in the Clockwork package does. Very interesting.
