Detail curve by curve+ from clockwork won't draw model lines
I am kinda new to the all dynamo thing. I have been trying to use the node DetailCurve.ByCurve+ from Clockwork with the intent of drawing some model lines usable on my revit file. I run a test with a simple curve and it won’t work. It doesn’t seem to have any error, I just can’t find the model detail line on the revit file. What is weirder is that at some point it worked, then I closed revit and dynamo and now is not working again. I am prbably missing something essential but if you could help me out that would be great cause i can’t find anything about it and it seems I have made every step correctly.
Try to import the line into Revit by Using " ModelCurve.byCurve" node.
shut the front door
