Dalux add-in block the use of dynamo
Hi everyone
I’m have a problem with an add-in call Dalux who is block the use of dynamo. It happen in Revit 20, 21 and 22.
Problems I have discovered is:
  • Nodes dosen’t show, only the wires.
  • Dynamo crash when i want to load packages.
    None of these problems appers when I remove the add-in from Revit.
Do anyone discovered similar issues with add-in’s, and maybe have af solution?
I tried this on 4 computers now, and waiting on an answer from Dalux about the issue.
Thanks in advance.
Andreas.
Hello and welcome here…i have the same here just on speckle…look here
There are many examples of add-ins causing conflicts which prevent Dynamo (or other add-ins, or even Revit) from working. The solution is to first ensure you have the lastest version of your add-ins (yes al of them) installed, and then work with any which are causing conflicts to get into matching version(s).
Dalux have sendt out a new update for the add-in, and dynamo works now.
Thanks for the your time and reply.
