Code Block not working due to conflict
@Daniel_Hurtubise @kslifter we have a workaround that requires replacing your Dynamo installation, if you’re up for it, here are the instructions: Dynamo code block not working in Revit 2023 - #13 by teocomi - Help - Speckle Community
Hopefully we’ll be able to find a proper solution soon :slight_smile:
@Michael_Kirschner2 something else I could try is building locally exactly the same versions that was shipped with Revit and that is causing problems, can you point me to the right commits?
  • this is my local build (not sure why the Core version is 2.13.0, as the tag I’m on is v.2.13.1):
  • this is the offcial one:
