Cannot enter text into Input or Code Block node in dynamo revit 2023
You have tried to leave and relaunch Dynamo and/or Revit
cordially
Christian.stan
Yes, a couple of times. but it no success.
Hello @londonZ7F92 could be an addin issue try to disable your addin and see it could help…btw do you have speckle installed ?
yes i have speckle installed
Allright thats prbably why…there are some problem with speckle…they work on a fix for that but in the meanwhile you can disable speckle addin and should work hoppefully :wink: for disable you could use Diroots app manager as is free…hope it could help
Wow, Thank you. I left the speckle add-in in Dynamo, but removed in Revit. yes it working now.
But I couldn’t understand, I have two devices, only on my PC was the problem. on my laptop the speckle didnt clash with dynamo
Yeah hope we soon find a real fix for that :wink:
Hi @londonZ7F92 …seems they have fix it now :wink: if you update to 2.13 from speckle manager it should work at least for me :wink:
