Customise PDF output name
Search for the threads on the form dealing with batch printing. Most will expect you to use different plotters but can generally handle custom file naming. Dynamo cannot override the behavior of a regular print, instead you would need to initiate/run the print using Dynamo.
For example:
Noting this is not a workflow I’d suggest you begin with if you are 100% new to Dynamo. Better to work your way up to it via the fundamentals such as via the Dynamo Primer.
