Customise PDF output name
I am looking to simplify how I PDF our drawing sets,
Currently PDF via bluebeam comes out as “file name” - Sheet - “sheet number” - “sheet title”
would it be possible to pdf and the files come out as
“Project Number” “Sheet number” - “current revision” - “Sheet title”
I am new to dynamo so would love some help.
Many thanks
Search for the threads on the form dealing with batch printing. Most will expect you to use different plotters but can generally handle custom file naming. Dynamo cannot override the behavior of a regular print, instead you would need to initiate/run the print using Dynamo.
For example:
Noting this is not a workflow I’d suggest you begin with if you are 100% new to Dynamo. Better to work your way up to it via the fundamentals such as via the Dynamo Primer.
Aside form Dynamo, you could use File > Export > PDF which is available from Revit >= 2022
this is what I have just found out about an hour ago - perfect solution. thankyou!!
