Customized PDF filenaming
To all, this is just a query. I have search the forum if there is a way to create a pdf from sheets with customized filename so far what i can find was create pdf using archi-lab package and rename the pdfs created afterwards. There are too many links, topics etc to attached here.
I do not have graph made or scripts made. I simply asking if someone out there can tell me is this possible straight from dynamo (one step process). I do not know if i will be wasting my time for something that cannot be done.
Some of you may in the past has already investigate this and may be able to give me a positive answer.
Thanks for your time…
Yes, that’s possible. There are plug-ins like RTV Tools for example that already take advantage of that. Cheers!
@Konrad_K_Sobon
Thanks for that Konrad. I will see if I can do it thru dynamo.
:slight_smile:
Here’s a tip: http://archi-lab.net/printing-pdfs-from-revit-why-is-it-so-hard/
