I want to automatically turn the roof into a multi-surface, what node should I use?
就像以下圖片
loft, sweep, or import from rhino
See also Geometry for Computational Design here:
http://dynamoprimer.com/en/Appendix/A-4_example-files.html
You’re going to want to investigate Dynashape from @LongNguyen. Installer Here -> DynaShape
and here is a video demonstrating this
and the graph I used
Dynashape-InflateRevitRoof.dyn (36.8 KB)
Nice quick example John. Thanks
Thank you very much for @john_pierson and @LongNguyen reply,That’s what I need
But I found a problem with the installation
I tried using the installer
try using manual method
There are still problems, do not know where the problem, please advise, thank you
Hi, Please try this new installer for version 0.3.1.2 here http://bit.ly/2w4ZZmF
I follow the steps of your code
But in the last part of this link is wrong
Please advise
Thank you
What version of Dynamo do you have?
I use dynamo 1.3
So I had a TeamViewer session with @helen60932111PLHPF yesterday and we were able to fix the issue. It was just that the ViewExtensionDefinition XML file was not set up correctly.
Dear Long,
I would like to achieve the vortex-shape shown in the image with DyndShape to determine the true minimal surface area and I am completely stuck. The surface boundaries (sections) are an ellipse and a circle. (the surface generated in the script is just an indication/sketch of what I am trying to build with DynaShape) Any idea how to start this with an ellipse/circle-based surface boundary?
many thanks in advance
Oliver
Here is my approach.
Hope you will get it working.
Bests
Long
Many thanks for the swift reply! I will give it a go!
best regards
Oliver
