Curve.Offset operation failed
I’m getting below warning when trying to offset a curve.
Curve.Offset operation failed.
Curve join produced more than one WIRE in PolyCurve
Hello …you feed in a polycurve the node ask for curves…probably something here would help…
Tried this node too but the same warning. I also tried to recreate this simple-shaped curve by connecting some points along the curve but it also failed with the same warning.
sounds like your curves is not in plane
Yes. It’s not. Any workaround? I want to offset it both sides with respect to z axis/plane.
Hello @theshysnail
“PolyCurve.Offset”
Same warning. My curve is not planar. It’s sloping up and down.
You could use Geometry.Translate - not the same as offset, but might be what you’re looking for
