Creating shaft openings from intersected elements
hi all,
im a new learner of dynamo and trying to create shaft openings from two different elements. In other words, for example i want to create a shaft opening where wall and pipe intersects.i try something but not good here is the script.is there anyone can help me
thanks in advance.
Ekran%20Al%C4%B1nt%C4%B1s%C4%B12
Either upload the files or show us what data the other nodes are returning please.
you’re trying to feed polysurfaces in a node that needs curves.
shaft.dyn (36.9 KB)
i could not manage to upload the revit file since the size is too big but as an example i just draw 3 pipes to the 3 different walls. the main goal is to make a shaft opening where two elements intersects.
thank you
any idea to convert it correctly?
Yeah like this:
thank you for your answer
However i still got null values . what might be the problem? do you have any idea?
Have you tried it on this file? Maybe you can send this file for us to look at.
Also send a screenshot of your script.
im sorry i could not upload it because of the size problem.but the revit file is so similiar , just 3 walls and 3 pipes.here is the screenshots of both revit and dynamo script
Shaft openings are vertical openings. The pipes you drew are horizontal.
Perhaps you want to look at wall openings?
I believe Bakery has a node for that.
yes you are right. i tried it and again null values. what do you think abaut the inputs?
Translated by moderator:
Here you can find something to help you solve your problem, I look for the same thing but in bars instead of walls.
Aqui podrás encontrar algo que te ayude a resolver tu problema, yo busco lo mismo pero en trabes en lugar de muros.
Hi @duzenlimehmett, may I ask you what is the package of the node “Openings.ShaftByCurves” please?
