Hello to everyone,
I’m trying to insert wall openings in the architectural model at the intersection with the ducts but it does not work. Someone can help me?
Thanks in advance
The results is somethings like this…
Hello to everyone,
Thanks in advance
Hi @onofriolofu,
This topic has been covered numerous times on this forum - you should be able to find topics that will help you along with what you are trying to achieve.
You can also check out this workflow from Bimorph for inspiration.
I’ve seen all of the previous posts and none of them works. Moreover none of the previous posts explain the workflow and the packages used to build it
Aqui deberías encontrar algo que te ayude
None of the links in that post is working…so if someone can help is the welcome
