I am trying to create openings in walls where ducts pass through them. I have been using this code I found however it does not work, it find the correct locations but revit error says cannot create openings. is there anyway to modify this code?
Forum 1|555x500
clr.AddReference(‘RevitAPI’)
openings =
walls = IN[0]
points = IN[1]
direction = IN[2]
width = IN[3]
height = IN[4]
for idx in range(0,len(walls)):
if direction == ‘x’:
ULX=(points[idx]).X - width[idx]/2
ULY=(points[idx]).Y
ULZ=(points[idx]).Z + height[idx]/2
UL = XYZ(ULX/304.8,ULY/304.8,ULZ/304.8)
DRX=(points[idx]).X + width[idx]/2
DRY=(points[idx]).Y
DRZ=(points[idx]).Z - height[idx]/2
DR = XYZ(DRX/304.8,DRY/304.8,DRZ/304.8)
ULX=(points[idx]).X
ULY=(points[idx]).Y - width[idx]/2
DRX=(points[idx]).X
DRY=(points[idx]).Y + width[idx]/2
opening = doc.Create.NewOpening(UnwrapElement(walls[idx]),UL,DR)
doc.Regenerate()
openings.append(opening)
OUT = openings
