Create Floor with Openings - Python, Dynamo
Hello guys!
I’m trying to set a sript to create a Floor with Openings in Phyton + Dynamo.
But, When I run my script I get this Revit Error (No code error).
I would like to know what’s happening here
If you can help me, I’ll appreciate you
This is my code:
import sys
sys.path.append('C:\Program Files (x86)\IronPython 2.7\Lib')
import System
from System import Array
from Revit import GeometryConversion
clr.AddReference("RevitAPI")
app = uiapp.Application
Curves = IN[0]
FloorType= UnwrapElement(IN[1])
Level = UnwrapElement(IN[2])
Is_Structural=IN[3]
OpeningCurves=IN[4]
RVT_Opening = CurveArray()
for i in OpeningCurves:
	RVT_Opening.Append(i.ToRevitType())
#Convertir RVT curves a CurveArray
RVT_Curves = CurveArray()
for i in Curves:
	RVT_Curves.Append(i.ToRevitType())
#Creación del Piso
Floor = doc.Create.NewFloor(RVT_Curves,FloorType,Level,Is_Structural)
Opening = doc.Create.NewOpening(Floor,RVT_Opening,True)
OUT = Floor
Okay never mind my other answer.
The solution is simple. You have to regenerate the current Document after making the floor and before making the opening. This way the document registers the new Floor.
import sys
import System
Curves = IN[0]
Is_Structural=IN[3]
OpeningCurves=IN[4]
for i in Curves:
#Creación del Piso
#Regenerate the Document to make sure the Document Registers the Floor
doc.Regenerate()
#Creación del Piso
OUT = Floor
I added one line:
doc.Regenerate()
Thank you!!!
It works!!!
Hello, I am a beginner in dynamo, I want to make a circular opening on a circular floor. What inputs did you put at “IN0” and “opening curves” ? because I entered a circle that represents my floor and a smaller circle that represents my opening. This does not work.
Hi @kevin3
for each loop (outer and inner) try with 2 joined arcs instead of 1 circle
Hello
Thank you for your help, unfortunately it still doesn’t work. It shows me an error without this line “for i in OpeningCurves:” @c.poupin
Sincerely
@kevin3
here is an example with arcs
update code for Revit 2022+
import sys
import System
clr.AddReference("System.Numerics")
#import Revit API
clr.AddReference('RevitAPI')
#import net library
from System.Collections.Generic import List, IList, Dictionary
#import transactionManager and DocumentManager (RevitServices is specific to Dynamo)
sdkNumber = int(app.VersionNumber)
curves = IN[0]
floorType= UnwrapElement(IN[1])
level = UnwrapElement(IN[2])
is_Structural=IN[3]
openingCurves=IN[4]
if sdkNumber > 2021:
	outer_Curves = List[DB.Curve]([i.ToRevitType() for i in curves])
	inner_Curves = List[DB.Curve]([i.ToRevitType() for i in openingCurves])
	outer_curveloop = CurveLoop.Create(outer_Curves)
	inner_curveloop = CurveLoop.Create(inner_Curves)
	floor = Floor.Create(doc, List[CurveLoop]([outer_curveloop, inner_curveloop]), floorType.Id, level.Id)
	rvt_Curves = CurveArray()
	for i in curves:
		rvt_Curves.Append(i.ToRevitType())
	floor = doc.Create.NewFloor(rvt_Curves, floorType, level, is_Structural)
	doc.Regenerate()
	rvt_Opening = CurveArray()
	for i in openingCurves:
		rvt_Opening.Append(i.ToRevitType())
	opening = doc.Create.NewOpening(floor, rvt_Opening, True)
OUT = floor
Hello, you added this namespace ( clr.AddReference("System.Numerics") ), but you don’t use it here in the rest of the code (that’s right)
this is an improved boiler plate code
As a curiosity
Thank you
Cordially
christian.stan
just because I was testing Ironpython3
and The Python int type in IronPython 3 is implemented as System.Numerics.BigInteger (and not as System.Int32 as it was in IronPython 2)
so a collection with a cast of int become list of BigInteger
comparison with Ironpython2 and CPython3/PythonNet
more explanation here
