I am facing a strange issue when I am trying to generate a structural opening with “newopening” object in Revit API 2021.1 on [Dynamo Python] C channel framing. Generated opening punchouts are off-centre by 5/8" or so from where it should be. But the reference geometry in Dynamo shows up in the correct location. It looks something like this
Where as it should be like
This is the Dynamo script
InvartedTrackAnchoreboltPunchout.dyn (116.1 KB)
and here is the python script
clr.AddReference('RevitAPI')
from Autodesk.Revit.Creation import *
clr.AddReference("System")
import math
openings = []
beams = IN[0]
loops = IN[1]
for i in range(0,len(beams)):
el = doc.GetElement(ElementId(beams[i].Id))
ca = CurveArray()
for c in loops[i]:
curve1 = c.ToRevitType(True)
ca.Append(curve1)
opening = doc.Create.NewOpening.Overloads[Element, CurveArray, eRefFace](el, ca, eRefFace.CenterY)
openings.append(opening)
OUT = openings
Any help or suggestion will be great!!!
