I’d like to add Material Tags to the layers of a wall. I’ve managed to create points at the centre of the wall layer, offset to the right, which is where I would like the tag to be positioned, but I can’t seem to get material tags to associate with the wall layers.
Clockwork has a node, the name of which escapes me at the moment, but search for “CompoundStructure”.
I believe the node you are referring to is FamilyType.CompoundStructureLayers, which I am using to retrieve the layer widths to in order to position the points.
Can I use one of those outputs to host the tag?
Ah! Misunderstood the question.
Gimme a minute to think on this…
Since you have the location already, this should get you started: Auto Material Tag - #6 by Alban_de_Chasteigner
