Hello there,
First of all i’ve got a background into coding (Java) and I’m wanting to learn more about Dynamo !
With that said; i’m aiming onto creating a Dynamo script that will select my corridor, extract the feature lines and export them into seperate DWG files so that the construction team can use them.
Big question is : Where do i start from ?
Best place to start is here:
From there download/install Camber which is a great C3D package.
If you’re familiar with API’s then the C3D help page has you covered also:
https://help.autodesk.com/view/CIV3D/2020/ENU/?guid=GUID-DA303320-B66D-4F4F-A4F4-9FBBEC0754E0
Hi @Cyberflow!
Install Arkance, Camber, Civil3D Toolkit packages at first. Also Monocle for fast search of nodes.
Than use search for “corridor”,“feature lines”.
Hi @GavinNicholls Thank you for replying !
Il’l give a good read on the “The Dynamo Primer” page that will be a mandatory read for me before kick starting this !
Thx for the links !
Hi @Vladimir , thx for the heads up !
By the way, where do i found those packages ?
It is usually easiest to get packages here:
More info in the primer:
