I was wondering if there’s any package that has added anything corridor transition related to it? I imagine it’s not an easy task and it’s relatively new to C3D so I wasn’t sure if there just hasn’t been enough time to develop it and I’m assuming this isn’t a job for those who thankfully create packages for us.
Corridor transitions are easier to manage in C3D24 but it can surely become a much more streamlined process with the help of Dynamo.
FYI for anyone who is interested in corridor transitions and utilizing them, an AU class was done and includes exactly what I’m talking about regarding implementing them. Not sure if Elliot Grubb is on here but gotta give a shout out to him!
There are also a ton of other great classes that have been posted regarding Dynamo use with C3D.
I have another update for this! After developing a script that will create multiple transitions at once, I ran into an issue where it would wipe out the previous transitions. I reached out to Elliot Grubb and he was able to fix this issue. Here is the updated python node. This should no longer wipeout existing transitions and allow for continuing to create them after changing variables in the Dynamo Player dialog.
import sys
import traceback
clr.AddReference('AcMgd')
clr.AddReference('AcCoreMgd')
clr.AddReference('AcDbMgd')
clr.AddReference('AeccDbMgd')
editor = adoc.Editor
corridorin = IN[0]
transetname = IN[1]
saname = IN[2]
paramname = IN[3]
startstation = IN[4]
endstation = IN[5]
startvalue = IN[6]
endvalue = IN[7]
def SetTransitionVaues(tran,startstation,endstation,startvalue,endvalue):
with adoc.LockDocument():
with adoc.Database as db:
try:
tran.StartStation = startstation
tran.EndStation = endstation
tran.StartValue = startvalue
tran.EndValue = endvalue
tran.TransitionType = CorridorTransitionType.Linear
return tran
except:
return traceback.format_exc()
try:
#Get corridor and baseline regions for first baseline
corr = t.GetObject(corridorin.InternalObjectId, OpenMode.ForWrite)
baselines = corr.Baselines[0]
#Count number of baseline regions
blregion = baselines.BaselineRegions[0]
#Get existing transitions
transets = baselines.getTransitions()
#Create the transet
transet = CorridorTransitionSet(transetname, blregion, saname, CorridorTransitionNameType.SubassemblyName)
i=0
noOfTrans = len(endstation)
while i < noOfTrans:
tran = transet.AddTransition(paramname)
SetTransitionVaues(tran,startstation[i],endstation[i],startvalue[i],endvalue[i])
i += 1
transets.Add(transet)
baselines.SetTransitions(transets)
t.Commit()
output = transet.Name
except:
output = traceback.format_exc()
OUT = output
This depends on if you used the IronPython2 engine or the CPython3 one (I have my suspicion based in how it is written that it is designed for the IronPython2 engine) . And if you were using IronPython2 it will depend on if the people consuming it are ok with the security issues therein (I wouldn’t be).
Sorry for reviving an old thread, but do you have the full dynamo graph for this? I tried using the new python code with the graph from AU 2024, but I can’t seem to get it to work with multiple starting stations. It produces the transition sets but doesn’t actually seem to input any of the data. So I’m curious how your overall graph is setup.
