I am about to begin a project that involves creating a high number amount of wall types. I was just wondering if anyone has ever come up with a script that could speed up the process of creating wall types with different layers of materials etc. Maybe this a lot to ask for and cannot be achieved but I would just thought i’d ask the forum as I am currently brainstorming. Thanks.
This is an interesting question… I don’t believe there are nodes for doing it and it seems to require a bit of setup…
From this post’s link it seems that you can’t just create walls, and you cannot even add layers to walls… So all you can do is start with a template which contains a number of walls with different wall layer quantities…
Then you can maybe start to duplicate, rename and edit the properties of those pre made walls?
It is true that it is not possible to create a system family starting from scratch but you can add layers and there is already a node : Create Compound System FamilyType in Genius Loci package.
As you point out, the method is to duplicate a type and edit it (add layers, materials, functions, thickness, limits of Core layers)
This node works with compound family Types : Walls, Ceiling, Roof and Floor.
hi alban! thanks for posting this, that’s just what i was looking for! Can you please help me figure out the method to duplicate a type in dynamo? thank you!
Sorry to bump this thread but I think this question is best kept here rather than starting afresh.
I’m trying to use this node to create multiple wall types. I have all the data as lists but I can’t figure out how to set the levels in the node to get all the walls created. It works fine with a single list for each input but not nested lists - can you, or anyone else who may be reading this thread point me in the right direction? I feel I should know how to do this but I just keep drawing a blank!
Hello Keith, I’m also doing a similar script to create multiple system families with multiple layers, but I’m a beginner so the lists and levels topic is still difficult for me. How did you manage to get the material grouped under lists as shown in your image?
This script was using Excel data to build wall types based on British Gypsum type data so it was all being derived from there. I would suggest if you have a specific issue you start a new thread and the awesome folks that frequent here will help you out. Be as descriptive as you can and be sure to post your latest attempts to solve you issue as that makes providing help much easier.
It kinda is related to the post, i try to make wall types procedurally. Actually I just need different widths but this approach seams to be to most promising!
I do have the ironpython 2.7 package installed, but 3.0 instead of the requested 2.4
so i try to downgrade to that.
I did not include a screenshot because its so minimal i did not think it would be nescessary
I am taking it step by step, trying to understand whats happening, but sadly i am rather stuck on the first step.
Good chance its some incompatibility with the ironpython package. I will continue to try the downgrade
EDIT:
and indeed, 2.7 version 3.0 was the issue. with 2.7 2.4 it works
thank you for this super fast response.
I dont quite now why i just now got the notification that i need that requirement.
