Hello
I’ve searched the forum and didn’t find the awnser yet.
I’m trying to create a button that simply creates a tag for the selected element.
After running this …nothing happens. What am I doing wrong?
Hello
Hi @kboschJGDNZ,
You’re probably using Revit 2019. The Tag creation changed in the Revit API.
You can use Create Independant Tag
in Genius Loci package instead.
This is an update of the Create annotation Tag node.
Thanks to Konrad Sobon for making the original one.
Thanks, that did the trick. I’m indeed using Revit 2019.
Congrats with your birthday!
Thanks !
You’re welcome !
i created roughly the same script, using Create Independent Tag but nothing happens. currently using Revit 2019
Welcome to the forum Anas.
This topic is already solved and your error is unrelated to the original post.
Please start a new topic and you will get help quickly.
