I get an error using Create annotation tag.
If i use the node Tag.ByElementAndLocation it works whit the input but i want another TagType.
I know that i can set the appropriate tag in revit and also i can manage somehow to replace the TagType but i wonder why this error appears.
Thanks Edwin
Hi @EzDoesIt,
And a flatten node between Point.ByCoordinates and TagLocation input.
Thnks but new error appear
What version of Revit do you use ?
“Create annotation Tag” node no longer works with Revit 2019.
Use the “Create Independent Tag” node in the Genius Loci package instead
Thnks that is it. I am using Revit 2019.
Your “Create Independent Tag” works fine.
