Annotation Tag Issue
I used create annotation tag node and it created tags but in a view different than the active view, which I don’t know which one.
Can you please help me figure it out.
thanks
Have you tried using the ID numbers (in green) to locate them in Revit (using the Select by ID tool)?
This worked for me from Springs package
I did search them by the ID number in green but it says no good view found. I eventually made it work but by just changing the list lacing and removing flatten list
thank you all for your help
