How does it work? Some extrusions go in horizontal, some vertical.
The solid i can create just out of standard primitves.
I want (like in the pic) create extrusion with to voids(cicle/cylinder)
Some tricks for me?
KR
Andreas
Some tricks for me?
KR
Andreas
you want closed top or as in extrusion ?
Yes, and cicles should be open! is there something like x.Curves
can you share your graph?
test.dyn (62.7 KB)
alternativly it could be solid … … you know via boolean Solids - cut out!
Try with external cure with Surface.ByPatch then minus the two circles.
Thank you… i will try other day! I does not work, because Dynamo does not know what are the “tap-curves”
Maybe you know just convert tap edges to curve or soemthing like that…
