hi, i am new to dynamo and having issue
trying to make a openings by using solid/difference but it doesn’t work
i made a tunnel-look-like structure (surface sliced) then made it solid by thicken
i want to make openings with solid (circle>extrude) but it never works the way i Think
Hi @sol !
It looks like it works only with the first extruded circle, is that what is wrong ?
If it is the issue you can try to change the level of the “other” input of your Solid.Difference node, or make a single solid by union the 3 cylinders.
You can make a surface with the circles using Curve.Patch and then extrude the surface with Surface.Thicken, there is two nodes, one single side and one both sides.
thank you so much
