Dynamo shows error when creates solid from lines
Hi everyone, I extracted a list of lines from filled regions.
I successfully create solid from polygon by point it worked. But it has the chamfer at the corner. Which i dont like. I prefer the round corner as shown in the filled regions’ lines
Then I tried to create solid.byloft from the list of lines but Dynamo shows error as curve are not closed.
Please help, thanks!
Hi @Marcel_Rijsmus I created a new post, can you help me please? Thank you.
Hey,
Could you post a test file?
Just a small thing to try… PolyCurve by points, instead of Polygon by points.
Best of luck :slight_smile:
Mark
Hi @Mark.Ackerley, thanks for reply. I just follow your advice, tried Polycurve, Dynamo still created solid with angle chamfer instead of round corner. attached. create family 2.dyn (79.8 KB)
Hey,
Ok… instead of the points, how about polycurve by joined curves? :slight_smile:
Cheers,
Mark
IT WORKS ! Thank you so much!
Great :slight_smile:
