I am currently trying to create sheets and views in dynamo using the sheet. by name number title block and views node. it seems to be working correctly with the exception that the views i am placing on the sheets is being cropped with a scope box and it appears that dynamo is seeing the whole site when trying to place the view on the sheet. i keep getting an error that reads “Warning: Sheet.ByNameNumberTitleBlockAndViews operation failed.
View 0 could not be packed on the Sheet. The sheet is 3.5 x 2.49999999999998 and the view to be added is 32.6844454521172 x 19.3759699010614” is there a way to get the node to register the cropped view from the scope box?
It will take the cropped view so make sure your view is cropped properly and the scale is set.
What does the view look like when you manually place it on the sheet?
