Hi forum,
I am trying to create a bunch of Shared Parameters (SP) for a major TitleBlock review.
Revit creates the parameters but the Node “Parameter.CreateSharedParameter” gives me the following error:
" Warning: Parameter.CreateSharedParameter operation failed.
Invalid parameter type."
The other Problem is that every Parameter is assigned to all the Categories in the Category List ( Sheets & Project Information) and not like i intended: only the one in the CSV.
I allready checked Lacing of the node, it is set to “shortest”
i attached all the files except the Revit project since i used a blank project.
I had to change the csv extension to “txt” for the platform to accept it.
i am running
dynamo 1.3.2.2.2480
Revit 2017.2
Any ideas what i am doing wrong?
thanks a lot in advance
CreateSPwithDynamoAndCSV.dyn (15.2 KB)
Input - Copy.txt (809 Bytes)
