Hello, i’m strulling to create a new shared parameter in the project with Dynamo 2.0.
i’ve tried to use the category node ans the all category node but no luck yet. he tells me that the parameter Type is wrong all though
is a string .
thank you
is a string .
thank you
Guys, I’m reading over but cant get any results. I did the same of you talbimam but I get nulls.
I créated A shared paraméter group into Revit named “METHODES”
Need to create over and rename several times shared parameters and project parameters, I really look for a solution.
Looking forward any help
Regards,
Erol
