Might it be easier to fix the DWG in AutoCAD?
JOIN, or even OVERKILL.
HI, your dynamo is amazing! but it is not putting in the right fittings assigned to that pipe type
That is right, but it will not make the fitting as you would like. It uses the routing preferences of the pipe chosen from your project.
hi could you please post the custom notes here too?
the pipe from line one …
Hello, can i get dynamo script for CAD lines to pipe ?
This will work for versions of Revit up to 2025: AutoCAD drawing to Pipes, Ducts or Cable Trays – Dynamo scripts
Hi @SPARTAN , any chance you could help us update this to work with Revit 26? It won’t work with anything newer than Revit 25. Thanks,
