I would like to create pipe or duct from DWG link (line or polyline).
Do you have an idea ?
Hi @c.barribaud
Try this Create Duct From CAD.dyn (7.6 KB)
DYN script. Below is the process in action:
Trying you DYN script on REVIT 2016 with dynamo 1.2, I have somme errors:
Polycurve.Curves :
Warning: No function called Curves on a
Autodesk.DesignScript.Geometry.Line that takes __array could be
found
Curve.StartPoint :
Warning: Internal error, please report: Dereferencing a non-pointer.
Curve.EndPoint :
Create Duct :
Warning: IronPythonEvaluator.EvaluateIronPythonScript operation
failed.
File "<string>", line 36, in <module>
TypeError: NoneType is not iterable
On which REVIT and dynamo version does it work ?
Do you have an idea about my errors ?
Hi Kulkul,
I get the following error. I am newbie sorry for silly question but if there is any package I need to download please let me know
Current Document Custom Note: Error: Custom node definition is not loaded!
Another question can I use conduits instead of ducts?
Thank you so much @Kulkul for sharing the good work. I’ve be struggling to design the graph by myself. Hope I’ll now complete my work by using your example. Many thanks, stay blessed : - )
If it is done according to different sizes, that’s fine
@Mihavel Add below lines in python and you should be fine:
OUT = DocumentManager.Instance.CurrentDBDocument
@Kulkul sir… I added your python script… Still it is not done sir…Again some errors… Please check the attached screenshot…
Python code should be replaced with missing Current Document node. You shouldn’t add in Create Duct.
Thanks in advance
