Hello everyone, I am new to Dynamo Revit, I was trying to create a concrete floor on floor 1 respecting the contour of the beams and columns, that is, by panels. I have managed to extract the column and beam curves from an entire floor, but what I cannot create is a surface within these curves that surround the slab panel. I leave the dynamo file and a photo. If you could give me guidelines to proceed, I would greatly appreciate it. greetings.
crear losa.dyn (72.0 KB)
crear losa.rvt (7.3 MB)
Thanks sovitek, if it is that surface that I am looking for, one that respects the contour of the columns and beams and then transforms it into a floor.
I was very grateful. Greetings and keep practicing to improve more.
Thank you Christian.stan, for your help I will see and improve the script right now. I’ll tell you how it goes. greetings dear.
Christian.stan
great, thank you dear. I am already understanding the functionalities of the nodes.
I am very grateful for your solution. ![]()
Hello. I was trying to create a concrete floor. I sorted points in clockwise. how can i get this contour? @christian.stan , @sovitek
