Create dimension, does not work?
so i want to create a simple dimension, it almost works, but “XYZ” is for any reason not defined so whats going on?
grafik
grafik
import sys
clr.AddReference('RevitAPI')
clr.AddReference('System')
walls_ = FilteredElementCollector(doc).OfClass(Wall).ToElements()
dTypes = FilteredElementCollector(doc).OfClass(DimensionType).ToElements()
linearTypes = [d for d in dTypes if d.StyleType == DimensionStyleType.Linear]
linear = linearTypes[0]
line_ = UnwrapElement(IN[0]).Location.Curve
opt = Options()
opt.ComputeReferences = True
opt.IncludeNonVisibleObjects = True
opt.View = doc.ActiveView
references = ReferenceArray()
def isParallel(v1,v2):
    return v1.CrossProduct(v2).IsAlmostEqualTo(XYZ(0,0,0))
for wall_ in walls_:
    for obj in wall_.get_Geometry(opt):
        if isinstance(obj, Solid):
            solid = obj
            for face in solid.Faces:
                if isParallel(face.FaceNormal, line_.GetEndPoint(1) - line_.GetEndPoint(0)):
                    refernces.append(face.Reference)
                    pass
            pass
nd = doc.Create.NewDimension(doc.ActivView, line_, references, linear)
OUT = "done"
KR
Andreas
Try using the subtract method instead of the generic operand.
It should work with the operand so you might want to return the endpoints and make sure you’re getting valid values as well.
@Nick_Boyts ,
thanks for the advice
what does it mean in practice?
    return v1.CrossProduct(v2).Subtract(XYZ(0,0,0))
Need i “subtract” my values from X,Y,Z ?
The error is coming from this line.
