Python code for getting the dimension is not working
Hi All,
Here I’m facing an issue with the python script. Requesting your hearty support.
clr.AddReference('RevitAPI')
from Autodesk.Revit.DB import Document, Wall, Parameter, \
    FilteredElementCollector, BuiltInCategory, UnitUtils, UnitTypeId
# Get the current Revit document
# Get the Structural Columns category
category = BuiltInCategory.OST_StructuralColumns
# Create a filter to collect only structural columns
filter = FilteredElementCollector(doc).OfCategory(category).WhereElementIsNotElementType()
# Initialize an empty list to store the column lengths
dimension_values = []
g = []
# Iterate through the filtered columns
for column in filter:
    # Get all parameters of the column
    parameters = column.Parameters
    #g.append(parameters)
    # Iterate through the parameters
    for param in parameters:
        # Filter for parameters of type "Dimension"
        if param.StorageType == Autodesk.Revit.DB.StorageType.Double:
            # Get the parameter value
            value = param.AsValueString()
            g.append(param.Definition.Name)
            # Add the value to the dimension_values list
            dimension_values.append(value)
# Set the dimension parameter values as the output of the script
OUT = dimension_values,g
#OUT = (dimension_values, g)
Regards,
Sanjana
Can you Post the error you are encountering in the output node?
A screenshot from Dynamo environment would be more helpful for us to understand the issue. Please, make sure that input data are visible for the python script.
if it concerns the dimensions of Structural Columns it is necessary to access the parameters of type
    FilteredElementCollector, BuiltInCategory, UnitUtils, UnitTypeId, GroupTypeId
structuralColumns = FilteredElementCollector(doc).OfCategory(category).WhereElementIsNotElementType()
g = []
for column in structuralColumns:
    columnType = doc.GetElement(column.GetTypeId())
    parametersType = columnType.Parameters
    for param in parametersType:
        if param.StorageType == Autodesk.Revit.DB.StorageType.Double and param.Definition.GetGroupTypeId() == GroupTypeId.Geometry :
