Creating dimension where is the error?
hello,
i try to put dimensions
import sys
clr.AddReference('RevitAPI')
clr.AddReference('System')
walls_ = UnwrapElement(IN[0])
dTypes = FilteredElementCollector(doc).OfClass(DimensionType).ToElements()
linearTypes = [d for d in dTypes if d.StyleType == DimensionStyleType.Linear]
linear = linearTypes[0]
line_ = UnwrapElement(IN[1])
opt = Options()
opt.ComputeReferences = True
opt.IncludeNonVisibleObjects = True
opt.View = doc.ActiveView
references = ReferenceArray()
def isParallel(v1, v2):
    return v1.CrossProduct(v2).IsAlmostEqualTo(XYZ(0,0,0))
for wall_ in walls_:
    for obj in wall_.get_Geometry(opt):
        if isinstance(obj, Solid):
            solid = obj
            for face in solid.Faces:
                if isParallel(face.FaceNormal, line_.GetEndPoint(1) - line_.GetEndPoint(0)):
                    references.Append(face.Reference)
                    pass
nd = doc.Create.NewDimension(doc.ActiveView, line_, references, linear)
OUT = "Done!"
where is the error
KR
Andreas
Hey,
I think you need to get the geometry curve from the detail line, then try to get the end points from there?
I don’t tend to use defs until I’ve got everything working, just because i find it harder to debug :slight_smile:
I also use dir() a lot :slight_smile:
Hope that helps,
Mark
