Creating Dimensions in families
Hello everyone,
I’m trying to create dimensions in a Revit family file. The build-in node, Dimension.ByElements, doesn’t allow me to do this since this is programmed only to work in project documents. I attempted to write my own script, but I’m not very well aquainted with python.
Bellow is the script i’ve written myself:
clr.AddReference('RevitAPI')
opt = Options()
opt.ComputeReferences = True
opt.IncludeNonVisibleObjects = True
items = UnwrapElement(IN[0])
lines = IN[1]
view = UnwrapElement(IN[2])
references = ReferenceArray()
for reference in items
	references.Append(reference.Reference())
for line in lines:
	try:
		createddimension = doc.FamilyCreate.NewDimension(doc.ActiveView, line.ToRevitType(), references)
		message = "Succes"
	except:
		message = "failed"
OUT = [message]
I believe it must be possible since I found this example written in C#
https://jeremytammik.github.io/tbc/a/0539_dim_walls_it_face.htm
