Create dimension between edges of FilledRegion
Hi! Im trying to create lenear dimension. But script fails to get reference from boundary of FilledRegion. Need some help, please:)
clr.AddReference(‘RevitAPI’)
clr.AddReference(‘System’)
def perpline(x):
p0 = XYZ(x,1,0)
p1 = XYZ(0,1,0)
ln = Autodesk.Revit.DB.Line.CreateUnbound(p0,p1)
return ln
def lines(HP):
linesArray = ReferenceArray()
for n, l in enumerate(HP.GetBoundaries()[0]):
if n == 0:
linesArray.Append(l.Reference)
if n == 2:
return linesArray
t =
FR = UnwrapElement(IN[0])
Perp = perpline(10)
View = doc.ActiveView
linesArray = lines(FR)
dim = doc.Create.NewDimension(View, Perp, linesArray)
OUT = dim
