Hi I get this error when I’m using create annotation tag. Will this work for keynote placement as well? Is there a way to set the leader and length?
I think like that as per you want.
If a comment solved your problem, mark it as solution
I will! going to try soon! thanks Robert
In the end i want to use this to Keynote walls at there center location but testing it i cant even get it to work on a door. not sure whats going on. same error
show me your revit snip when you select element. and show your full graph of dynamo.
boom! thanks so much man
Is there a node that works for keynote tags? This dosnt seem to work for keynote tags
