Could not construct input curve for Floor.ByOutlineTypeAndLevel
I am trying to create this floor with Dynamo.
I have created a nurbscurve using the perimeter vertexes of the floor, but the construction of the face fails. I believe this must be due to non co-planar issues. What approach should I have to solve this?
Many thanks!
1-094-SA-PAL-EXPO_ATENOR-AQ-R00A_Cobertura14.dyn (70.9 KB)
Hi @RitaAguiar
You could solve this way:
And here is the result in Revit:
Hi @Kulkul, can you share how you did it?
I’m having trouble with the shape. It is being pulled onto the XY plane and it becomes a plane slab.
Just Add this:
I noticed that you’re using old version of clockwork.Make sure you’re using clockwork 1.33.1 version:
Here is the DYN file For Rita.dyn (79.7 KB)
RVT File Here For Rita.rvt (1.5 MB)
Thank you @Kulkul
I have updated Dynamo to 2.0.3 and installed clockwork 1.33.1.
However, I haven’t been able to reproduce the result you obtained.
I must be missing something (?)
1-094-SA-PAL-EXPO_ATENOR-AQ-R00A_Cobertura32.dyn (259.8 KB)
You should select a normal floor type. It does not work with foundation slabs.
Thank you, that worked! @Deniz_Maral
Is there a way I can obtain an actual floor with the curves?
Floors:
Structural Foundations:
Ideally, I would like to obtain this shape of category Floors.
