I’m having difficulty opening a Dynamo graph which recently crashed. The file has been developed in Dynamo 2.0.1 and running on Revit 2018.3. A colleague has managed to open the file in Dynamo 2.0.1 using Revit 2019.1, but I cannot replicate this on my machine. I’m guessing a package or custom node I have downloaded maybe corrupt, but I cannot open / isolate the issue.
Has anyone else come across a similar issue or could take a look at the .dyn please?
I’m relatively new to Dynamo but have been using this forum to gain a greater understanding for some time now, this forum has been an invaluable resource for info. Thanks for any help.
Hi there,
I’ve downloaded the script and I can’t open it. my revit also chashed.
I used my trick and I can open it:
I used Dynamo player and edit the script. To use Dynamo player properly, before use it you have to open Dynamo, select Dynamo 2.0, close it and open Dynamo player, then select the script and edit it.
I tried to open using Dynamo player as you suggested but still couldn’t open / replicate your result.
I’ve removed and reinstalled some packages, then recreated the graph in Dynamo 2.0 from scratch and it appears to be working fine. I can only think a couple of the nodes I had used were not updated for Dynamo 2.0.
