OK I have been kicking around some things for some time using multiple resources. and here is my question. Is there a way to copy all elements from a view and paste it into another projects view using dynamo. here is where I am at.
here is my workflow
- select all elements from a view and set up a parameter to record the elements discipline and id number ( demo, temp, existing)
(complete) - copy all the elements in a view but level 0,0 (basically like window select then copy)
(working on) - open another project and paste the copied elements into the view on level 0,0
(not even close) - using the new added disciplines and id number convert all the elements to the proper phase (demo,temp,existing)
(complete)
so I can manually do the 2 and 3 but want to make it (kiss) keep it simple stupid. right now I do it with three buttons 1st button makes the parameter on all the objects
2nd button adds the parameters to all the elements in a pre set up view. (I then have to copy all the elements. (window and control c)
3rd button in the new project after I paste all the elements to level 0,0 adds the parameter back to all the elements so the correct phases is added.
