Combine calculated value text parameter in schedule
I am creating a door schedule that include fire rating values. to avoid duplicating door families (same properties except fire rating value) to make fire rated type mark, I created it as an instance parameter and created a calculated value parameter for tagging based on it.
that’s the current result now
So in my schedule I have 2 columns (Type Parameter and Calculated value - text parameter)
I want to combine them into one new column. can anyone guide me to do it?
Hello @Na7as …welcome to our community!..you could try to join your values to an single line and the set the parameter…
Thanks @sovitek!
I don’t need to create another parameter, Is there any way to make as a combined parameter with that calculated value parameter (FRxMark)?
Hello…i dont talk about another parameter just feed your joined value into FRxMark parameter…
I miss something here, how can I feed the joined value again to the FRxMark parameter (calculated value)?
I still don’t know how i can feed the joined value to the current parameter :frowning:
aha its a calculated parameter you will write to…my bad…didnt read it right ;).is it the same parameter you get the value from? in that case you need a new one for the joined value…if you want you can share the file and i take a look…
If that’s going to be your Door Tag, then wouldn’t you need it to be a single shared parameter to tag anyway?
@Nick_Boyts …yeps :wink:
