As a standard, my office wants to use a different font vs. the default Arial text font in annotation families. I began to open each individual annotation family, select edit type and changing the Text Font from Arial to a font of their liking and then saving the file and deleting the backup file. This seems a bit tedious. My understanding is that Dynamo can help with these tedious tasks. I am very new to Dynamo and interested in learning how to create these dynamo scripts. I’ve seen a topic here and began to create a script. When I do a search for some of these nodes, it seems that I am not finding the proper nodes.
try this
import sys
import System
clr.AddReference('System.Drawing')
from System.Drawing import Text as DText
#import Revit API
clr.AddReference('RevitAPI')
fontName_to_set = IN[0]
allFontName = [fa.Name for fa in DText.InstalledFontCollection().Families]
if fontName_to_set not in allFontName:
raise Exception("Error", "This text Font is not available")
remove_subClass = System.Predicate[System.Object](lambda x : x.GetType() == clr.GetClrType(DB.TextElementType))
lst_textNoteType = List[DB.Element](FilteredElementCollector(doc).OfClass(DB.TextElementType).WhereElementIsElementType().ToElements()).FindAll(remove_subClass)
for textNoteType in lst_textNoteType:
para_noteFont = textNoteType.get_Parameter(BuiltInParameter.TEXT_FONT)
para_noteFont.Set(fontName_to_set)
OUT = lst_textNoteType
i am in a family enviroment, but what should happen?
The previous example works only for annotation families (for labels), here a version should be works with TexteNotes too
import sys
import System
#import Revit API
lst_textNoteType = FilteredElementCollector(doc).OfClass(DB.TextElementType).WhereElementIsElementType()
