I would like to move the Elevation view location leaving where it is the Elevation Marker ?
From
To
My “hopeful” attempt
Any idea?
From
To
Any idea?
Directly connect Select Model Element to Element.MoveByvector.
Thanks @Nissal,
I get error,
I select the Elevation View not the Elevation Marker, as I want to move only that.
After Select model element, use Transcation.Start node. and connect this node with Element.MoveByVector
Cheers man but still negative.
I also noticed that If I select the elevation view on plan I get “Element”.
If I retrieve the Elevation View via ElevationMarker.View I get the actual view.
They have consecutive IDs.
Share your .rvt sample and dyn file here
Have you guys had any progress on the issue? I’m having the exact same problem.
