Create elevation view by element
I’m trying to create a elevation view by element.
In my specific case, i select a specific element in revit (a wall) and i want to built a elevation view that crops to the extents of this wall.
I’ve seen this article, it teaches how to create elevation view by model curves, i tryed to adapt it to my context but it did not work. Can anybody please help me?
The error i get is the following image
Elevation View Generator.dyn (39.7 KB)
Thank you all in advance.
The python script expects a list of Elevation Marker Points and not a single point. (Select multiple walls)
The downloaded .dyn seems to work.
LearnDynamo_Module_2 (dynamo 2.0).dyn (87.4 KB)
Is there a way to adapt that for a single one?
It works but with one or several walls the result doesn’t seem to be perfect.
Did you already try the ViewSection.ByLine node in Data-Shape or the Create Element View node in BIM4Struc ?
#Copyright(c) 2016 www.Learndynamo.com
#Please contact at jeremy@learndynamo.com
clr.AddReference('RevitAPI')
from math import *
toggle = IN[0]
point = UnwrapElement(IN[1])
modelPoints = UnwrapElement(IN[2])
cropCurves = UnwrapElement(IN[3])
viewType = UnwrapElement(IN[4])
lst = []
#Get Family View Type
vft = 0
collector = FilteredElementCollector(doc).OfClass(ViewFamilyType).ToElements()
#eleViews = []
for i in collector:
	if i.ViewFamily == ViewFamily.Elevation:
		vft = i.Id
		break
if toggle == True:
		#Retrieve the mid point of model lines and get X,Y.
	modelMP = modelPoints.ToXyz()
	modelMPX = modelMP.X
	modelMPY = modelMP.Y
		#Retrieve individual lines of crop window.
	cropLines = cropCurves
	l1 = cropLines[0].ToRevitType()
	l2 = cropLines[1].ToRevitType()
	l3 = cropLines[2].ToRevitType()
	l4 = cropLines[3].ToRevitType()
		# Create a line in the z-Axis for elevation marker to rotate around.
	elevationPT = point.ToXyz()
	elptRotate = XYZ(elevationPT.X, elevationPT.Y, elevationPT.Z+100)
	ln = Line.CreateBound(elevationPT, elptRotate)
		#Calculate the angle between Model Mid Point and Elevation Point.
	elevationPTY = elevationPT.Y
	elevationPTX = elevationPT.X
	combY = elevationPTY-modelMPY
	combX = elevationPTX-modelMPX
	ang = atan2(combY, combX)
		#Create elevation marker and elevation in position 0.
	eleMarker = ElevationMarker.CreateElevationMarker(doc, viewType.Id, elevationPT, 100)
	ele = eleMarker.CreateElevation(doc, doc.ActiveView.Id , 0)
		#Rotate elevation marker towars model line.
	ElementTransformUtils.RotateElement(doc, eleMarker.Id, ln, ang)
	crManager = ele.GetCropRegionShapeManager()
		#crShape = crManager.GetCropRegionShape()
	newCurveLoop = []
	newCurveLoop.Add(l1)
	newCurveLoop.Add(l2)
	newCurveLoop.Add(l3)
	newCurveLoop.Add(l4)
	cLoop = CurveLoop.Create(newCurveLoop)
	try:
		crManager.SetCropRegionShape(cLoop)
		lst.append("Elevation Created")
	except:
		pass
		lst.append("Missed Elevation")
	OUT = lst
	OUT = "Set toggle to TRUE"
I did, but it creates a section view. In my case, what i really need is an elevation view.
Thanks for your help!
Edit: I haven’t tryed the one from data-shapes, but looking at it now… it doesnt seems to work
I used your code and it doesn’t work with any walls.
I used the node ElevationMarker.CreateElevation Marker from the Rhythm package and it created a marker with the view. The problem is that i canot update the view crop region through dynamo. Is there a way to do so?
Thanks !
In this case, use this dyn with the updated python script.
LearnDynamo_Module_2 (dynamo 2.0) V2.dyn (88.2 KB)
Thanks for you support man.
But unfortunately, even this new code keeps returning me the message Missed elevation
Me too, but the elevation view is still created at the correct location.
In some cases it is… in most it is not created. When i use the node ElevationMarker.CreateElevationMarker from the rhythm package it always creates the elevation at the correct spot. There is a node from the clockWork package called ElevationMarker.Views. with him i could get the views associated to the elevation marker. He is not currently working. His code is this one:
clr.AddReference(‘RevitAPI’)
def GetElevationMarkerView(item):
val =
if hasattr(item, “HasElevations”):
if item.HasElevations():
for i in range(item.MaximumViewCount):
view = item.Document.GetElement(item.GetViewId(i))
if view: val.append(view)
return val
items = UnwrapElement(IN[0])
if isinstance(IN[0], list): OUT = [GetElevationMarkerView(x) for x in items]
else: OUT = GetElevationMarkerView(items)
Any tip on how to fix that?
I suggest you create a new topic with your new question (ElevationMarker.Views node) and link it to this page.
The original subject with the error in the python script is resolved even though your elevation creation problem remains the same.
For now, I do not have time to edit other scripts.
Thanks for your support.
That’s what i’ll do.
Hi, I recreated this in 1.3 but I get this error.
Any advice ?
Cheers
Hi @simoneavellini , can you show what you have in line 46 and what the inputs look like?
It seems you need to go one (or more) step deeper into the list, to be able to extract the xyz attribute from the point and not the list of points.
Hi there,
Thanks for all your work done here. @ramoon.bandeira and @Alban_de_Chasteigner I got curious, why some of the views are not being correctly created, and why on earth the output message was always “Missed Elevation” even though all of them are properly (apart from crop region). I looked into the code and I’ve found out, that since 2016 Revit API has changed in that area. In the ending of the code, when we are trying to set the crop region, crManager.SetCropShape(loop) method should be used instead of crManager.SetCropRegionShape(loop).
Cheers!
İ was trying to use that script @Alban_de_Chasteigner shared.
Elevation Missed warning reason is changed API method.
> 		try:
> 			crManager.SetCropShape(cLoop)
> 		except:
> 			pass
this part was
     try:
  	crManager.SetCrop*Region*Shape(cLoop)
This method is from 2015 API now depracated.
After that change it’s working perfect.
Cropped Wall elevations generated. :smiley:
Same message pervious one :frowning:
Hi @kaankrby,
I’m a bit confused. Do you mean you are still getting the same warning message? Cound you share some more details?
No :slight_smile:
i didn’t read your message completly,
And started to digging script and the api methods
When i find the solution i writed here
So
after reply i noticed that u writed same thing :frowning:
Hi all. I get the same error as @simoneavellini even though im using Revit 2022 and Dynamo 2.12.
@m.souza did you ever find a solution?
Im using the dynamo script that @Alban_de_Chasteigner posted - the Module 2 V2 script.
The python script looks like this.
from math import *
toggle = IN[0]
lst = []
vft = 0
#eleViews = []
for i in collector:
		vft = i.Id
		break
if toggle == True:
	newCurveLoop = []
	try:
	except:
		pass
	OUT = lst
