Hi, trying to set an elevation markers location to the center of the room their in without moving the elevation view. Thought a marker would just be a point location, not curve.
any leads on this one? I’m facing the exact issue.
It is possible to move the Elevation Markers :
I will update the SetLocation node in the next version of the Genius Loci package or I can sent you the updated node if the task is urgent.
Thanks a lot for the update. I had to modify the script from moving existing Markers to “Create New Markers and its elevation” at the desired location point. It’s not much, but its something.
It’s not urgent at the moment, so I’ll wait for the update
trying element.movebyvector but no luck either. Its not cause the points 0.5 off from working out the center as a solid is it?
ok so this worked, says null but worked
Merry Christmas
Here is a present @vanman
Hope it does this do the trick
Move Elevation Markers.dyn (29.8 KB)
haha I love it! thanks Ewan. Sorry I posted to much of my thoughts figuring it out on the forum you might have missed I got it with element.movebyvector. Appreciate the help though! Keen to see your method
Ah, all good.
There is a good example of dealing with Document Units in the code in there anyway that should be of some help elsewhere.
