I make Longest Lacing for the node (Conduit.Byline) from the Package MEPover but the node produce only one conduit for line but i need to make a lot of conduits from one line depend on the number of diameters per line
Hello @mohamed.eissaEP3P4
Have you tried setting the list levels?
Lines @ Level 1
Diameter @ Level 2
https://primer.dynamobim.org/en/03_Anatomy-of-a-Dynamo-Definition/3-1_dynamo_nodes.html
Edit: Hm it look like the amount of lines and diameter lists does not match, what is your purpose?
You have to set the levels at the input of the Cables Output node ![]()
i model the cable as conduits ,and in the infrastructure projects i have conduits which have cables inside it so the same conduit has a lot of cables so for the same conduit (one line) i want to model a lot of cables with the same size or different
i tried to edit in the node by adding for loop ( the diameter) before for loop (lines) and it has been solved
this the node before edit
and i added for loop for diameter
thanks a lot for your help @gerhard.p
